Just get a small test light(bulb with 2 wires) disconnect a batt cable and hook bulb in between cable and batt post. If bulb lights, you most generally have a drain. Not sure about newer tractors, but newer cars lot of them will show drain that is not really there. Multimeter is not much help on old tractors, need analog tester with moving needle, but then you gotta watch plus and minus or burn out meter. Ohms is for readings where you do not expect any voltage. Ohms the meter is using its own little batt to read through meter.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
