Re: Janicholson .....H Carb Float Closing Needle
Posted by Janicholson on November 30, 2008 at 19:33:47 from (66.188.163.79):
In Reply to: Re: Janicholson .....H Carb Float Closing Needle posted by Tweeter on November 30, 2008 at 18:18:35:
Yes. It is necessary to be tender and gentile. a little is a lot, and a bit more is broken. if it has a dimple in it from wear, it can be soldered with non lead solder pretty easily (use a pencil type iron, and do it with least heat to make it flow. Then file down the tab, and polish. JimN
