Re: multitester/battery drain
Posted by El Toro on December 01, 2008 at 06:00:10 from (64.12.116.73):
In Reply to: multitester/battery drain posted by bellyacre on November 30, 2008 at 18:39:06:
third party image
Your regulaor may be the cause of the battery drain. You can install a master switch between the tractor frame and the negative battery cable. This will isolate the battery from ground.
You will need another short battery cable from the tractor frame to the master switch and connect the existing ground cable to the master switch. The military has used these for years.
Hal
