Re: C-263 gas with oil seep burning
Posted by glennster on December 01, 2008 at 06:05:36 from (76.222.57.166):
In Reply to: C-263 gas with oil seep burning posted by bc on November 30, 2008 at 21:49:33:
usually excessive blowby is caused by worn rings, however, it could be caused by other things too, ie, cracked piston, blown head gasket ect. the oil by the exhaust is more than likly coming past the rings and getting in the exhaust manifold, not burning off and dripping out. run a dry and then wet compression test, first, pull all plugs, throttle wide open, ignition off, test each cylinder, write the numbers down, then squirt 2-3 pumps of engine oil in each cylinder, roll the motor over couple times and retest. more than 10% variation, and the rings are worn, low compression with no change, look to valves, head gasket or cracked head. you are prooly due for a major on the motor, but if its a year or two away, try tossing a can of stp oil treatment in the crankcase, it will thicken the oil up and cut down on some of the oil consumption.
