Re: H battery hookup ... HELP!
Posted by Bob M on December 01, 2008 at 11:32:24 from (151.190.254.108):
In Reply to: H battery hookup ... HELP! posted by New H-boy on December 01, 2008 at 11:18:21:
Not to worry about causing permanent damage by running with the battery polarity reversed. Those old generator systems pretty much could care less about ground polarity.
Suggest you do this (assumes your H still has the original generator - not a 12 volt alternator conversion):
1 - Hook the battery cables up so the POSITIVE post is grounded.
2 - Now turn on the lights and note which way the ammeter needle swings.
3 - If it swings left (discharge) skip to step 5.
4 - If the ammeter swings right (charge), REVERSE the cable connections at the battery.
5 - Polarize the generator: With the engine stopped, momentarily jumper between the BAT and GEN terminals at the voltage regulator. (Soon as you make contact - you may see a small spark - you have successfully polarized the generator)
Your tractor is now set to run positive ground - like it did from the factory.
Today's Featured Article - History of the Field Marshall Tractor - by Anthony West. Any restorer who has some knowledge of turn of the century farm machinery, will recognize the name Lanz Bulldog!! This machine was to say the least unusual in its appearance. The huge flywheel and coffee percolator shaped exhaust. Along with square body lines and cylinder head protruding forward of the front axle. Would become the visual differentiation that people would quote to separate the Lanz from other period machines. The Marshall company based at the Briannia Works in Gainsborough ... [Read Article]
