Farmall F12 shift pattern
Posted by Lyle Breese on December 01, 2008 at 16:51:36 from (66.81.53.182):
For the owners of the Farmall F12 and F14 who are having trouble fiquering out the shift pattern on these tractors.(the gear ratio is so close on these tractors it is hard to tell what gear your in for sure). Reverse is a no brainer though.
Looking down at the shifter from the seat, there are 4 bolts that hold the shifter in place.
The bolt on the bottom left is the Reverse position.
The bolt on the top left is 2nd gear.
The bolt on the bottom right is 1st gear.
The bolt on top right is 3rd gear.
None of the manuals I have seen show a shifting position diagram. The decal kits I have purchased for these tractors do not include a shifting pattern decal.
