Tony - You won't screw anything up reversing the primary wires on the coil. (Incidentally the coil will still spark OK even if it's wired backward).
I'd check the coil carefully to make sure it actually requires an external resistor (photo). If it does not, delete the resistor! Also make sure the points are correctly gapped (.020) and the condenser is good.
A good coil, points, condenser and wiring will provide more than adequate spark for an M - electronic ignition is really NOT necessary!
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati
... [Read Article]
Latest Ad:
[More Ads]
