Posted by D Slater on December 01, 2008 at 18:54:14 from (71.164.47.121):
In Reply to: Re: C152 Compression posted by D Slater on December 01, 2008 at 18:16:19:
Will add that the last time I priced a new distributor shaft from IH the price was sky high. You can tell which shaft you have by removing breaker point support plate, weights and springs, then you should find a number stamped on weight mount part of shaft like L22 or L40. 22 indicates 22 total crankshaft degrees advance or 40 would be 40. Could be another number if distributor was switched from something else. Most well used distributors have the total advance hole worn where the point cam goes in hole so that total is going to be more than indicated though.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
