Okay, you're basing "weak spark" on assumptions. Spark is not where the power comes from. The BANG the spark creates is where the power comes from. If there's too much, or not enough, fuel in the fuel-air mixture, the bang will be weak, and the engine will not produce power.
If you want to verify the spark quality, remove a plug, put it back in the boot, and lay it against the engine block. Have someone hit the starter button while you watch the plug. Make sure the tractor is in neutral because it could start on 3 cylinders. You could disconnect the remaining 3 plug wires from their plugs to prevent that, just remember where they came from. I'll bet the spark is bright blue, which is perfect.
Unfortunately, your local advice, the one that's telling you to "go up a heat range" is just guessing. Whether that's because he's just taking your word on what's wrong, or he's trying to get rid of you, or he's trying to sell you more parts, or he's just clueless, is irrelevant. The heat range of the plugs is neither the cause nor the cure for this problem.
I believe you have a fuel delivery problem. The tractor won't start unless you "starve it for fuel" and will "flood" when you give it any choke at all. A carburetor service (I despise the word "rebuild" because all you're replacing is a few gaskets) including disassembly, cleanout, reset the float, etc. is in order.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
