Re: C152 Compression
Posted by TractormanNC on December 02, 2008 at 05:53:50 from (209.42.180.216):
In Reply to: C152 Compression posted by chad504 on December 01, 2008 at 12:22:10:
Might add the following, it may help some. Overhauled a SA with a mag and put firecraters init. Used an OH kit from IH which included two new distributor shafts. Of course I couldn't use the new shaft since they would not fit a mag. Mag had a 35 deg impulse coupling on it. Tractor would not run right at idle and mid range, ran ok at full throttle. Missing and sputtering. Finally replaced mag with a dist with one of the new shafts (20 or 22 deg) in it, tractor ran fine at all speeds. Hope this helps.
