Re: pulling front engine cover
Posted by Bob M on December 02, 2008 at 05:55:27 from (151.190.254.108):
In Reply to: pulling front engine cover posted by IndiRon on December 02, 2008 at 03:22:11:
I recently had the front cover off a couple different M's and a 400. Here's the deal:
1 - The fixed bolster assembly must be unbolted from the frame rails then slid forward several inches - or removed entirely - to provide room to remove the crankshaft pulley. On mine I drained the cooling system, removed the radiator hoses, disconnected the steering shaft at the U-joint then used a hoist to remove the entire front end and radiator assembly as a unit.
2 - The crank pulley is retained by large (2-1/2") nut on the crankshaft nose. A socket is required to remove the nut - it's in a recess and cannot be grabbed by a pipe wrench, etc.
3 - One the big nut is removed the pulley usually slides right off - no puller is required.
