Pulley has to come off after nut is removed as already posted, sometimes they come off easy and sometimes a good puller with a lot of pressure is needed. Make sure all but the lower inside bolt is removed from ignition drive housing, if steel plate behind front cover is going to need off you may as well remove ignition and drive completly. 2 bolts below drive need removed,also bottom bolt from governor housing. These have bolt heads to rear of tractor. Oil pan needs removed or at least loosened or bolts removed from front that go into front cover. If your going in to remove camshaft you may as well drop pan because the oil pump comes out before camshaft will. If you have all other bolts out of cover with heads to front of tractor, dowel pins and gasket seal is all thats left holding cover on.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
