You need a dual speed PTO assembly. They were available for 1086 and smaller tractors. Best to get the same style as your single speed unit. On later units the lever will drop out of engagement when the engine is shut off. That shaft also is free to turn with the engine off. If you do not get the same style you will also need to change some linkage. You will also need a different coupler inside the the rear frame. The 15 series uses a larger diameter drive shaft shaft so you need a coupler to adapt it to the smaller size on the PTO unit.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
