Re: Farmall 130, want opinions
Posted by Brownie 450 on December 03, 2008 at 04:09:44 from (216.51.158.151):
In Reply to: Farmall 130, want opinions posted by Hugh MacKay on December 03, 2008 at 03:55:34:
How is the oil pressure? Have you changed the oil regularly? If it has good oil pressure, chances are that it won't need much in the way of journal work on the crank. However, you would want to have the bearings measured just to be safe. Same for cam bearings--probably put new ones in.
I didn't work on an engine either until the first time.
