Hugh, these are some of the easiest engines to rebuild. If you have a little mechanical ability, some basic tools and you take your time, you can do it. You would also need to have some equipment to handle the engine safely.
A good local automotive machine shop would be an invaluable asset too. The machine shop can rebuild your head, and can evaluate your crankshaft to determine if it needs bearings and reground.
I have even bought bearings right from the machine shop.
If you have a warm place to work on it over the winter, it can be a good project.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
