Hugh, i dont think you will have any problems doing the major yourself. the head and crankshaft, send them out to a machine shop, have them do the valves, plane the head if necessary, and also check the crankshaft and cut it if required. i would have the machine shop get your bearings. may be a couple dollars more, but then you have the right ones.( i now have an extra set of 10 under main and rods for an m). with a shop manual, pretty much everything else is just dis-assemble, clean it all up and re-assemble. the major done by yourself will prolly run 800 or so including parts and machine work. when done, you will know what you have. when i do a teardown, i get a box of zip lock baggies, and label all the bolts and such and bag em. then when it comes time to re-assemble, you know where everything goes. give rusty farmall a shout for the engine o-h kit, he can set you up.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
