Re: FARMALL 400 MOTOR IS STUCK
Posted by spiffy1 on December 03, 2008 at 08:44:15 from (70.41.137.72):
In Reply to: FARMALL 400 MOTOR IS STUCK posted by Tom Fleming on December 03, 2008 at 08:31:16:
Head's off; all sorts of options now!
You can try driving them up with a jack or down with a post. Before that or between you can try a diesel/ATF mixture, your favorite rust breaker, or any other dozens of other people's favorite.
If it looks quite stubborn, you can burn the mixture in the holes to give some thermal cycling to allow the penetrant to sneak deeper; also, if you try wacking the piston just after the flame goes out (may want a rag around the post to protect yourself from any hot residue), a cold piston and warm sleeve should break easier.
See if you can get a pair to move up (a jack is a good option), then removing the caps on the other two you can drive them down putting force on only one at a time.
Have fun!
