My dad did in chassis overhauls on a C and H and it worked well for years. But that did not address the crank seals, just bearings and valve job and sleeves/pistons. Pulling an engine and using an engine stand makes it easy to do. and the satisfaction you did it yourself. Cleanup is a time consuming chore, but you get to see how good or bad everything is. Spot cracks etc. Buying another used tractor that vintage would bring up the question of how worn out is it? If you have money to spend then have someone do it. If it is a hobby do it yourself. Good luck
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
