i am thinking if the starter is staying energized and continues to spin, you may have an electrical problem, not actually the starter. hook up a test light to the big battery cable at the starter, it should not light. then try and start it, the lamp will light, but when you release the starter button, the lamp should go out and the starter stop running. if the lamp is staying lit, the solenoid is not opening. as you already replaced the solenoid, try hooking the test lamp to the small wire coming from the starter button to the solenoid, the one that energizes the solenoid, do the same thing and see if it stays lit when the button is released and the starter continues to run. this will at least isolate a solenoid problem, or a wiring problem before the soleniod
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
