Re: 574 starter want quit engaging after switch is released
Posted by Brownie 450 on December 03, 2008 at 17:48:44 from (216.51.158.151):
In Reply to: 574 starter want quit engaging after switch is released posted by johns48jdb on December 03, 2008 at 14:50:34:
With what you have said, I would suspect you are on the right track replacing the bushings. With bad bushings,the starter is going to draw more current & the main contacts are welding as Tooly said. The other possibility is that the Bendix is either gummed up on the starter shaft or is dry or rough on the shaft & won't retract from being engaged with the ring gear.
Possibility # 2 is that the Bendix is hanging up[clutch is locked up]. If this is the case, a new Bendix is probably in order.
Check for roughness on the starter shaft[helix].
