Re: need shut off valve
Posted by Big Red Man on December 03, 2008 at 20:20:57 from (24.206.106.13):
In Reply to: need shut off valve posted by b.runyan on December 03, 2008 at 17:53:25:
It may depend on which tractor or which model. Having said that, please bear in mind that it has been more than 50 years since I last saw our Farmall Regular. I believe the gas line ran from the gasoline tank straight forward then bent to the right, then took a "U" turn and entered the sediment bowl from the right. I believe the gas line exited the bowl from the left. The shutoff valves were at the back (closest to the driver) of each tank. I hope I'm right. Good luck.
