Mike, This method will unstuck your motor in short order, one Saturday!! 1 strip away all tin work, head and valve train assembly, fuel tank and lines pan and oil pump assembly, mark each then unbutton the rod caps. 2 tractor must be able to roll, in and out of shop 3 roll outside 4 Start with the cylinder that has the most volume. fill with Diesel add a splash of gas set it in fire, sit down drink a cup of coffee and let the fire burn itself out. 5 take a hammer and a wooden block and drive the piston out from the bottom. 6 repeat steps 4 & 5 with each of the remaining pistons. As the volume decreases in the cylinder they may need to fill up with Diesel and burn 2 or 3 times or more. The heat from the fire will break loose the rust and free up the piston. 7 Most Important....be careful of the fire, and getting other things on fire that you do not want to burn. Hope this helps. Later, John A
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
