Re: 574 starter want quit engaging after switch is released
Posted by Janicholson on December 04, 2008 at 09:46:53 from (199.17.6.128):
In Reply to: 574 starter want quit engaging after switch is released posted by johns48jdb on December 03, 2008 at 14:50:34:
If you turn the key off then on does it stop doing it?
If you unplug the little wire from the solenoid does it stop doing it.
If so a key switch might fix it.
If it is in the mechanism, try some TriFlow dry PTFE film spray on the splenoid plunger, and moving parts. Welding together contacts are the result of excess amps, the starter may need bushings, JimN
