Re: 574 starter want quit engaging after switch is released
Posted by mkirsch on December 04, 2008 at 10:35:41 from (64.80.108.56):
In Reply to: 574 starter want quit engaging after switch is released posted by johns48jdb on December 03, 2008 at 14:50:34:
You have replaced the solenoid, correct?
Assuming the new solenoid is good, there are only two other reasons why the starter continues to receive electricity after you release the button:
1. The button itself is sticking.
2. The relay that the button is activating is sticking (if equipped).
You got a nearly-rebuilt starter out of the deal, but you're barking up the wrong tree. This is an electrical problem, not a mechanical problem.
Check the starter button and all the wiring associated with it. If there is a relay in the path to the solenoid, check all its wiring as well.
