thanks for all the inputs. if i use the switch that i have put in the ground cable from the battery to ground of course it all stops. thing is that if i go back a few seconds later it doesn"t kick in again until i turn the switch on. since i have a new selonoid i took the old one apart. the disk that makes contact between the two leads inside the selonoid was not fused to the contacts. there was evidence of some arching, but nothing burnt or stuck. the yoke that pushes the bendix into the flywheel is badly worn and the bolt hole in it that it pivots on was worn also to where it was egg shaped. i"ve ordered the yoke, 12 from ih, i will put on a new selonoid and new bushing in it. the mid shaft bearing was real bad as well as the to end bushings. with me replacing so much stuff at once and it fixes the problem i really want know what cured it. that would disappoint me. i wil let you"ll know when i find out something. any hints between now and then appreciated.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
