Re: SUPER MD BOGGING AND SMOKING UNDER LOAD
Posted by Janicholson on December 04, 2008 at 18:32:12 from (66.188.163.79):
In Reply to: SUPER MD BOGGING AND SMOKING UNDER LOAD posted by ERIC FOX on December 04, 2008 at 17:09:35:
The key word is just. Give it time to get used to operating. The injection may be a bit out of time, and letting it get a few hours on it, then setting things to spec will help. See shifting farmalls into fifth in the search for box. I run full throttle in 4th, clutch in idle down shift sloishly (a bit of grind, like 6 teeth) then let out clutch and open it up. It is a 4 second shift. JimN
