Re: Lift-all Hydraulic Principles
Posted by Steven f/AZ on December 05, 2008 at 13:23:11 from (216.67.213.217):
In Reply to: Lift-all Hydraulic Principles posted by Chad504 on December 05, 2008 at 12:37:52:
The lever/valve on the Farmall belly pump Liftall system has 3 positions.
All the way forward is down (lets the implement/loader down or allows it to "float").
All the way back is lift (raises the implement/loader)
The middle position is hold (holds the implement/loader wherever it is at)
If you want to have a more useable loader, add yourself some 2-way hydraulics and a 2 or 3 spool control valve.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
