Re: Attn Bob M ~ Super C wiring/Charge Indicator Lights
Posted by Bob M on December 05, 2008 at 18:33:53 from (74.74.136.142):
In Reply to: Attn Bob M ~ Super C wiring/Charge Indicator Lights posted by AndrewFromNS on December 05, 2008 at 16:06:42:
Andrew - John T's identified the problem: The LED does not draw enough current to "turn on" the voltage regulator. (It takes a minimum of about 200 ma to turn the regulator....)
Solution is to add a bypass resistor wired in parallel with the LED/470 ohm resistor. The parallel resistor should have a resistance between about 12 and 40 ohms, and should be rated for at least 5 watts.
Or...wire a #168 indicator lamp in parallel with the LED/470 ohm resistor. Then hide the bulb inside the ammeter box. A bit crude perhaps - but it will work!
