STUCK VALVE ....CONT. SAGA FARMALL A:
Posted by Wild Bill Caldwell on December 06, 2008 at 18:18:28 from (67.33.127.171):
So Far....Drug the A out of a pine thicket for the old Man, Engine stuck....Kroil...ATF, 3 weeks later engine frees up....No fire....worked Magneto over....Bad carb. ..pulled a carb off My 240, engine started, I ran it a few minutes ,shut it down. Today I filled the radiator with water/antifreeze, cranked it up and let it run an hour, runs pretty good considerin' the last valve closest to the gas tank is stuck open (cyl.#4 I think it is the exhaust valve) I've been sprayin Kroil and pourin' ATF on this valve stem, any ideas on freein' this valve without pullin' the head? I've thought about takin' a brass drift, placein' it on the valve and hittin' it easy with a lead hammer.....Any other things Yaw'll have tried before?
Thanks
Wild Bill
