Re: Farmall IHC - Model 240
Posted by GordoSD on December 07, 2008 at 10:34:40 from (66.115.200.140):
In Reply to: Farmall IHC - Model 240 posted by russ landreth on December 07, 2008 at 08:03:21:
What clearnce is on the valves on those two cylinders? Don't have to be off much to give you 0 compression reading. If it is valve setting, and you continue to run it, and LOL, you will burn the valve and seats.
Gordo
