Re: Conversion from Key Switch back to stock?
Posted by Clarkbug on December 07, 2008 at 13:43:58 from (72.66.56.22):
In Reply to: Conversion from Key Switch back to stock? posted by Clarkbug on December 07, 2008 at 10:14:18:
Thanks for all the input everyone.
Ill post a picture if I can find one a little later of the current setup, just so you guys can see what I mean.
I am not really a stickler for original stuff, especially if it works well. However, I have already had one of the solenoids go bad, and Im worried that it might happen again in the future. Plus its something that if a part of the system does go bad in the future, Its going to be a real PITA to figure out what went wrong, since its such a custom installation.
I plan to keep the electronic ignition, along with the 3 wire alternator conversion that was done to it. I just like the push button starter switch instead of the key/solenoid version.
Durk, you bring up a good point. Ill have to talk the light box apart and see whats goin on in there before I go too much further... This could get to be an expensive proposition if Im not careful...
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
