12 Volt Charging System Made Right
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by IHank on March 29, 2000 at 19:14:32 from (167.142.25.27):
My F-450 came to me with a 12 volt system using the old style GM alternator. It had a little "gee whiz" box gadget, apparently as the voltage regulator and self excitor system. One day it would be a no charge situation and the next it would be a pegged ampmeter... In the days before tear down it was a no charge situation. I took the alternator apart and all was well inside. There was nothing wrong with the alternator. The little silver gadget had wires connected- one to ground, one to alt output, one to stator, and one to field. Humm... I got two points for hitting the junk bucket from across the room with it! The needed design correction and repair action was applied as follows- Told the car parts clerk I wanted a voltage regulator for a '65 Dodge. About 30 bucks got me a small black box with an electric terminal on opposite ends, one for power in and one for field current out. A jumper wire was made up, to connect the switch power side of the ignition resistor to the power in terminal, thru a 5 amp in-line fuse. Another jumper wire was made up, connecting the regulator output to the field terminal on the alternator. This system uses what appears to be the original generator bracket. The alterntor mounts on the front tab and the white ceramic Dodge style ignition resistor is on the rear tab. I bolted the regulator on the front side of the rear tab. All components are physically close together. This trick can be used with about any brand of old style alternator, the ones that use an external regulator. It is very important to tap into a switched 12 volt source before it goes thru any dropping resistors. Hope this info helps somebody else. IHank
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
