Re: Farmall IHC - Model 240
Posted by Janicholson on December 07, 2008 at 17:14:59 from (66.188.163.79):
In Reply to: Farmall IHC - Model 240 posted by russ landreth on December 07, 2008 at 08:03:21:
Pull the VC and see if a pair of valves are suck. If so PB blaster them and tap tap tap on the stem to free them. if they are operating OK, put an air hose in one spark plug hole, and (with the other spark plug out, see if air is gushing out the other. Blown Head gasket. Check the radiator, Air nrushing out Bad head gasket, or cracked head. Check the crank case Air here means blown pistons rings or possibly a chunk out of a cylinder. JimN
