Re: Farmall 460 Brake Question
Posted by John Athey on December 07, 2008 at 18:21:34 from (208.72.76.111):
In Reply to: Re: Farmall 460 Brake Question posted by Hugh MacKay on December 07, 2008 at 18:07:02:
Thanks for the advice on the glow plugs. As for the brake durm - there is a small screw / bolt thats goes from the outside in. Inside there is a small hole in the end of the screw / bolt and the small spring ataches there. What does the other end of the spring go to?
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
