There is a reason that they stopped using those push button switches and went to solenoids.
Push button switches tend to get burned contacts, and stop working after a while because you can't push the switch fast enough to prevent it from arcing. A solenoid makes the connection much much more quickly, and as such is much more reliable.
On an M, the proper location for the push button is at the base of the steering pedestal, with a little "flapper pedal" to push it with your right toe. These can be particularly troublesome because, well, they're down near your cruddy boots when you get on and off the tractor.
Ms never had the push button switch up on the steering post like an H where you could operate it with your hand, right up through the Stage I Super M. They switched to the "saddle" type directly on the starter sometime in 1953.
A solenoid setup really isn't too complicated, and it may be worth your while to re-wire what you have.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
