Re: QUESTION ABOUT A 1959 140 FARMALL.
Posted by Hugh MacKay on December 08, 2008 at 08:53:54 from (209.226.106.146):
In Reply to: Re: QUESTION ABOUT A 1959 140 FARMALL. posted by BDC on December 08, 2008 at 08:32:05:
Brett: A 140 block part number should read 367825 R1 or 367825 R2. Just maybe some of them ended in R3 or even just R. There should always be a blank between the 6 digit number and R.
If we agree that your block part number is 367825 R whatever then there is no way tou have 3" pistons and sleeves. The only kit ever made for that block is 3-1/8" piston and sleeve.
I thought you ironed out that serial number about 6 posts ago. I must admit, I've never seen serial numbers on a 140 with blanks other than between number and the J. If your tractor has a 4 digit serial number, excluding the J, it almost has to be a 1958, 1959 or a 1960. At this point, that is as far as I'm prepared to go. Getting info from you has been much like pulling hen's teeth.
