Re: amps drawn by 6volt starter on 12v conversion
Posted by Tom 43 on December 08, 2008 at 11:19:33 from (70.143.51.103):
In Reply to: Re: amps drawn by 6volt starter on 12v conversion posted by JMOR on December 08, 2008 at 10:17:57:
Dear JMOR and others,
Many years ago I checked the amp draw of a 12 volt system on an engine mounted on an engine stand with a Sun VAT-40. The draw was 185 amps. Then I substituted a 6 volt battery and the draw was 320 amps, with the engine turning more slowly. The same phenomenon will occur with a weak but not too weak battery. As the starter approaches stall, current flow rises as voltage drops up to a point. This apparent violation of OHM'S law is due to the fact that the starter is both a starter and a generator and when spinning rapidly produces a counter voltage reducing current flow. However, if we were to conduct this experiment with a locked engine, we would have a resistive rather than inductive load and OHM'S Law would be obeyed.
