Posted by Bob Kerr on December 08, 2008 at 13:22:36 from (63.134.174.164):
In Reply to: Farmall H thermostat posted by neblinc on December 08, 2008 at 09:18:01:
sounds like it might be air locked. That is there is air trapped in the block and it is getting hot spots that make steam and cause the temp gauge to shoot up. I would take the thermostat housing back off and drill a very tiny hole, smaller that 1/16th in the flat part of the thermostat. That will let the air pass through when filling and not be enough to by pass much water when running. Some thermostats have small valves built into the flange to do the same thing. Another trick is to have the front of the tractor raised higher when filling. Helps get trapped air out.
