Re: 1946 Farmall H Problem
Posted by ScottyHOMEy on December 08, 2008 at 18:01:10 from (71.241.214.215):
In Reply to: 1946 Farmall H Problem posted by CMR-SD on December 08, 2008 at 17:43:29:
Spark could be a problem, but from your description of the speed control lever being of little use, I wonder if maybe you need to re-synchronize the governor to the throttle, where you've had the carb off.
If this were an A,B or C, I could tell you how to do it. The governor is a while different set-up on the H, and I don't know it well enough to be able to describe it. If you can get your hands on an I&T IH-8 manual, it's at the end of Par. 161.
