Re: More H questions.
Posted by ScottyHOMEy on December 08, 2008 at 18:09:52 from (71.241.214.215):
In Reply to: More H questions. posted by Farmallb on December 08, 2008 at 17:02:41:
The distributor would be a cap on a cylindrical affair, and you should see a wire coming from another cylinder nearby (the coil) with a short heavy wire into the center post on your cap.
If a magneto, it is most likely an IH Model H4. On that, your distributor cap will be mounted to a body that is generally rectangular with a rounded bottom. On top of the rectangular section will be a rectangular cap, and the wire to the center of your distributor cap will come from that second cap.
