Re: 1946 Farmall H Problem
Posted by ScottyHOMEy on December 08, 2008 at 18:16:44 from (71.241.214.215):
In Reply to: Re: 1946 Farmall H Problem posted by CMR-SD on December 08, 2008 at 18:07:02:
It might still be possible that you are 180* out. Timing needs to be done at TDC on the compression stroke. If by chance you were at TDC on exhaust, you'll be 180 out.
Easy fix to test it would be to move all your wires at the cap to the post exactly opposite of where you have them now, i.e., swap #1 for #4, and #3 for #2. If that fixes it, that's the problem. After that it's up to your conscience whether you want to pull the distributor and retime it so that the wires are in the customary position for the next guy. ;8^)
