Re: 1946 Farmall H Problem
Posted by steelfronts on December 08, 2008 at 18:27:32 from (66.227.243.0):
In Reply to: 1946 Farmall H Problem posted by CMR-SD on December 08, 2008 at 17:43:29:
You have a problem in the gov. You can take the cover off the side and make sure things are freed up in there and since you are good at removing the carb now make sure the linkage is also free.It sounds like the gov weights arent able to do their job.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
