Posted by steelfronts on December 08, 2008 at 18:31:48 from (66.227.243.0):
In Reply to: M shift problem posted by iowafarmall on December 08, 2008 at 15:09:20:
You will have to pull the shifter out and align the shift raila and put the shifter back in. It takes only a few minutes. It happens because the shifter gets worn on the end. It can be built up with weld and ground back down to fix.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
