Re: 1946 Farmall H Problem
Posted by Clarkbug on December 08, 2008 at 21:00:07 from (72.83.180.127):
In Reply to: 1946 Farmall H Problem posted by Andy Motteberg on December 08, 2008 at 17:43:29:
To follow on that idea, make sure that when you put the carb back on, the lugs on the shaft coming from the governor are in the slots on the carb. Sometimes they can get out of alignment and things go wrong.
Also, you should have been able to flood out or starve your carb by adjusting the main jet on it. If you had gas running out of it, you could have some gunk still stuck in there somewhere thats causing your issues....
