Re: Gas tank dent on 130
Posted by Bill Hires on December 09, 2008 at 04:58:07 from (128.206.120.184):
In Reply to: Gas tank dent on 130 posted by EZ on December 08, 2008 at 20:06:20:
I use a pipe plug the size of the sediment bowl fitting with a hole drilled in it so a tire tube valve stem with the rubber removed will fit. I JB weld the stem into this hole and after it cures put the tank cap on and apply air pressure. I have never had to use more than 5-6 psi for the dent to pop out. I do have a spot welding slide hammer tool, but this air pressure method has worked very well for me.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
