Re: M shift problem
Posted by mkirsch on December 09, 2008 at 05:23:12 from (64.80.108.56):
In Reply to: M shift problem posted by Mike Farmer on December 08, 2008 at 15:09:20:
It's not stuck in two gears yet, only one. 99% of the time they end up stuck in two gears because the operator doesn't recognize that it's already stuck in one gear. Usually it happens when you shift from one gear to another.
What happened is the nub on the end of the shift lever is worn, and slipped out of the 2-3 shift fork with the tractor still in 2nd gear. The old remove-the-shift-lever-and-use-a-screwdriver-to-align-the-forks technique will fix it, but you need to build that nub on the shifter back up with weld if you can to solve it permanently.
For now, be VERY deliberate with your shifting.
