Re: OT Chevy 4.3
Posted by mattofvinings on December 09, 2008 at 06:50:36 from (198.208.159.20):
In Reply to: OT Chevy 4.3 posted by Deere40 on December 08, 2008 at 18:10:11:
The rough idle hints at a vacuum leak (or the EGR valve stuck wide open).
I would go thru and replace any suspect lines throughout the engine first. Napa makes a silicone vacuum hose which is thermal resistant and twice as flexible as the standard black versions. It costs a little more but you will find GM used different sized endforms on hoses for assembly error-proofing, and the silicone is flexible enough to adapt to this.
