Posted by bc on December 09, 2008 at 08:12:06 from (68.88.175.43):
In Reply to: Gas tank dent on 130 posted by EZ on December 08, 2008 at 20:06:20:
I was at the body shop yesterday. They use a hammering type dent puller and glue the end on the car. If glue breaks loose, they glue again till they get it. Either pull it out or use the sliding hammer to knock it out. Then alcohol takes off the glue without hurting the paint.
You can get the screw in hammer type dent puller fairly cheap and drill a small hole in the top to pull it. Then fill in with jb weld or something and grind it smooth.
You can buy the schrader air valves that already have a pipe fitting on them over in the lawn sprinkler section of lowest or home cheapo.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
