Re: Gas tank dent on 130
Posted by kossuth on December 09, 2008 at 08:43:56 from (214.3.140.16):
In Reply to: Gas tank dent on 130 posted by EZ on December 08, 2008 at 20:06:20:
<--- Nervious about using a stud welder on a gas tank. Not that you can"t do it I"d just be scared of "boom". Also applying air pressure creates possible bomb if you go crazy with air pressure. Eithor of these tricks the guys recommended will work just BE CAREFUL. Remember gasoline vapors are explosive!!!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
