Posted by bc on December 09, 2008 at 10:37:06 from (69.149.215.139):
In Reply to: Gas tank dent on 130 posted by EZ on December 08, 2008 at 20:06:20:
You could also slip some type of L shaped tool/angle iron/flat bar into to filler spout and lift up on it. If close to the spout, then maybe even some type of J shape tool or even a C clamp. Then pull it up or put a 2x4 block on top and tighten it up. Could do the same thing with some C clamp style vice grips.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
